Normal Oil pressure
Jaswir
578
Orlando, FL
on cold start up the pressure reads 50-55psi
and at idle around 700rpms once warmed up and drivin alot it sits at 20 on the dot!
then driving with the rpms goes up to about 30-35... just depending on how fast im going...
just wondering if 20 is normal with warm oil?
130,000 on engine and with Auto meter electric gauge
It's still safe but it's definitely on the downside of where it should be. Mine is 70 psi upon cold startups, then goes down to 60 psi when warm. At idle (when hot) it'll go down to 40 psi and then move back up to 60 psi when driving.
once i added my turbo i see about 22 a hot idle. i blame that mainly on the oil going thorugh the turbo and getting just a little bit hotter than it normally would. my buddy who is a ford tech told me the same thing as above, 10 psi for every 1000 rpm
