I have done alot of reasearch before doing my rear disc conversion on my 1990 GT. I have fox length Moser axles and purchased the North Race Cars SN95 disc conversion bracket and cable set. I just got around to painting and installing them last night and have an ISSUE Im not happy with that Ive already called NRC and discussed. With theyre kit installed the outer face of the rotor is about 1/16" away from touching the bracket, and the inner side has almost 1/2" of clearence. They claim this is normal in theyre instructions and that it is fine as long as they dont touch the rotor. I told them yes it may work but what happens when the inner pad gets worn half way down and comes out of the caliper bracket without warning.....
.....They said "thats why we include washers to shim to the proper length"....I told them if I wanted to "RIG" it to work I would have used the stock 94-95 brackets and cut them to fit then shimmed them. I dont want 2 1" round surfaces supporting the entire load and force of brake pressure. They said "we do it all the time and it works okay." I stated I payed $230 for perfection and it is not, and if I wanted washers and other **** I would have made my own. They claimed "you have all we offer and we cant help you, it might be out farther because you have 4.10 gears." WTF MAN...... F**K THOSE *******S.....THEY MAKE A HALF WAY DECENT ITEM AND CHARGE A PREMIUM AND THEN TELL YOU TO GET BENT WHEN YOU HAVE AN ISSUE.
thing moan like a mug...
