Northern Radiators
  • Thread starter Thread starter Cobain03
  • Start date Start date Jun 28, 2007
Cobain03
996
Lexington, Ky
Jun 28, 2007
  • Jun 28, 2007
anyone have one? im thinking of getting a direct fit 2 row aluminum one with a 3.5 inch shroud and a 14 inch 1550cfm fan. is there any problems with this combo? How much difference should i see with this setup? right now im stock (all new componets plus a 12/14 inch pusher fan with the stock engine fan) and i can bump 200 to 210 in heavy traffic.
coolblue65
1,224
Algonquin, IL
Jun 28, 2007
  • Jun 28, 2007
I put one in when I installed the 347, I got it ebay for $250 +shipping. So far really happy - quality looked great and the car seems to run cooler then ever.
C
chromedog
554
worlds center for speed
Jun 28, 2007
  • Jun 28, 2007
if everything else is up to par, you will see a pretty big difference... i have the same radiator, no shroud, and a generic flex fan, cooling a 351 windsor, and have no problems at all. the temp hasnt gotten over 180 so far this summer.that is with a lot of sitting around idling at 85 to 90 degree outside temp.
iskwezm
4,159
20
79
Rowland Heights,California
Jun 29, 2007
  • Jun 29, 2007
get a different fan, that fan doesnt pull enough CFM
HookandLadder
261
St Louis
Jun 30, 2007
  • Jun 30, 2007
+1 on a bigger fan. At least a 2200 would be my guess, but a mechanical fan with a shroud should work just fine with your combo.
5.0ina66
664
Ohio
Jul 1, 2007
  • Jul 1, 2007
+2 for a bigger fan
Cobain03
996
Lexington, Ky
Jul 1, 2007
  • Jul 1, 2007
well i ordered a setup. should be here tues/wed.
i think that the fan (14 inch 1550 cfm) and the 3.5 inch shroud is going to be the main key for cooling. the stock shroud is only 1 1/2 inches which really isnt anything compared. now i cant wait for the next really hot day.
side note, what kind of ratio of antifreeze/water should i run? it wont be ran in the winter obviously so just the other three seasons.
Vinyl66
398
  • Jul 1, 2007
Cobain03 said:
it wont be ran in the winter obviously so just the other four seasons.
Here in GA, Spring is a bit short and Summer is a bit long but we still only have 4 seasons.
My Northern Radiator works wonderfully to keep my 347 cool. I do use a Spal 2360cfm fan on it though. I use approx. 70% water and 30% antifreeze in mine.
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Engine Engine Bay crazy hot!
  • R82148V
  • Aug 28, 2023
6K
Fox 5.0 Mustang Tech Aug 30, 2023
Mustang5L5
