Northern Radiators
Cobain03
996
Lexington, Ky
anyone have one? im thinking of getting a direct fit 2 row aluminum one with a 3.5 inch shroud and a 14 inch 1550cfm fan. is there any problems with this combo? How much difference should i see with this setup? right now im stock (all new componets plus a 12/14 inch pusher fan with the stock engine fan) and i can bump 200 to 210 in heavy traffic.
if everything else is up to par, you will see a pretty big difference... i have the same radiator, no shroud, and a generic flex fan, cooling a 351 windsor, and have no problems at all. the temp hasnt gotten over 180 so far this summer.that is with a lot of sitting around idling at 85 to 90 degree outside temp.
well i ordered a setup. should be here tues/wed.
i think that the fan (14 inch 1550 cfm) and the 3.5 inch shroud is going to be the main key for cooling. the stock shroud is only 1 1/2 inches which really isnt anything compared. now i cant wait for the next really hot day.
side note, what kind of ratio of antifreeze/water should i run? it wont be ran in the winter obviously so just the other three seasons.
it wont be ran in the winter obviously so just the other four seasons.
Here in GA, Spring is a bit short and Summer is a bit long but we still only have 4 seasons.:D
My Northern Radiator works wonderfully to keep my 347 cool. I do use a Spal 2360cfm fan on it though. I use approx. 70% water and 30% antifreeze in mine.
