I don't like the NOSzle kit. I plan on switching to an NX plate kit myself. With all goodies (heater, WOT switch, window switch, etc...) I made the numbers in my sig dyno tuned. That is with 125 jets. Talk about unimpressed! People with the plate kit are making 485 or so torque. I make what 395 or something. NOT COOL. When you first hit it, it takes so long to fill the lines in the kit that there is a bad delay and what I consider a bad lean spike since the nitrous is under more pressure and goes through the lines faster than the fuel can (1000psi vs. 50 or so). I do have a purge and it helped a little. I hate that. Then when you shut the kit off at the end of the 1/4, it pulls the fuel out of the lines, floods the engine, and it dies on me 3 out of 4 times. The only way to prevent it is to just let off the gas with it in gear to keep the engine turning and cleaning the fuel out. This means backfire galore. Sounds horribly out of tune, but that is just the way the kit is. I usually just clutch at the end of the run and keep a bit of throttle in it to keep the RPM's up. That's rediculous for over $2500 invested in the kit. Those are the cons. Pros are that I never have to worry about a blown intake. Worth it? Hell no. Get the NX plate and the Gen X2 kit and be A LOT happier than I am. I really hope this helps you.
Oh BTW to change jets, you have to remove the injectors and fuel rail, take every noszle out and change 2 jets on each one, then put on new o-rings and reinstall. About 2-3 hours if you do it right. NX you just change 2 easy to reach jets by the intake. 15 minutes tops for an idiot, 5 if you're good.
