  • SN95 4.6L Mustang Tech
NOS Install - need help
  • Thread starter Thread starter Stark77
  • Start date Start date Jun 15, 2008
Stark77
501
Tallahassee, FL
Jun 15, 2008
  • Jun 15, 2008
Hey guys - first post over here, also a member on Yellow Mustang Registry. I just finished installing a wet Nos Sniper Kit for the 4.6l. I have everything installed with the exception of the arming toggle switch. I am very well oriented under the hood, but when it comes to the interior electrical system I am totally clueless!. How do I get wires from the engine bay to the interior( I ran my nitrous lines out the bottom of the hole in the spare wheel well, cable tied to the fuel lines, and up into the engine bay through right fenderwell). Besides being scared ****less of trying out the nitrous system, I'm in desperate need to find a way into and out of the engine bay from the cars interior ( need to hook up to a 12 volt powersource and also connect the lead to the throttle sensor). Guys, any help will be tremendously appreciated.
94GTHO
200
Richmond, Va
Jun 15, 2008
  • Jun 15, 2008
Alot of times people send the wire through a rubber grommet on the firewal that leads to the inside. Just loosen one up and run through there. Dont know how big your wires are through.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jun 15, 2008
  • Jun 15, 2008
the rubber grommet on the drivers side of the car works perfectly. it is just below where the clutch cable goes thru the firewall
Stark77
501
Tallahassee, FL
Jun 15, 2008
  • Jun 15, 2008
Ok, I will try in the morning. Do any of the trim/dash panels need to be removed? The main thing that I think would be getting in the way is the trim panel that meets with the door - the piece that has the hood release lever. should this be removed? The wire is very thin, enough to supply power to the LED light on the arming switch and it will be joining up with a prong on the the "wide open throttle sensor" that was mounted on the TB.
Thanks for the help yall.
Stark77
501
Tallahassee, FL
Jun 16, 2008
  • Jun 16, 2008
Issue resolved - NOS working very well!
d98gt
4,505
59
204
SE Texas
Jun 16, 2008
  • Jun 16, 2008
I ran my lines through the grommet on the driver side. I ran the lines under the middle console up through the hole and it hides well
Glad to see you got it working.
Stark77
501
Tallahassee, FL
Jun 16, 2008
  • Jun 16, 2008
Spent today installing a NOS wet/fogger kit on my 03 GT. I have already upgraded my intake manifold to the aluminum Typhoon intake manifold from Professional Products. I hit the street tonight(the benefits of working wednesday to saturday ) with a conservative 75 shot and 2 full 10lb tanks. I haven't installed a purge solenoid yet, so I activated the NOS and when I went wide open throttle at 40mph in 2nd gear I didn't notice a different..........for about a second until the lines cleared of the liquid nitro and the gas started pumping. I went from 40-70 in a blink. Once I had the lines cleared of the liquid NOS(it pools into liquid after a few minutes of being in the line due to the heat from underneath the car) and had the gas flowing, I did a 40-100mph test. Unreal. My car was putting down 289 rwhp and 312 rwtq before the NOS. The different NOW is very real. Tomorrow I will try the 125 jets.
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
T
Fox Help Request: Clutch Cable Installation on T5 Swap — I Can’t Find the Mounting Hole
  • TDM389
  • Feb 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2026
nickyb
Resolved 1996 PATS help needed
  • Bajaboy
  • May 21, 2025
SN95 4.6L Mustang Tech May 23, 2025
Bajaboy
R
Need a little help identifying this plug
  • redlineracing1328
  • Oct 7, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Oct 8, 2025
revhead347
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
