nos ok with aod?
  • Thread starter Thread starter trevnut
  • Start date Start date May 26, 2004
trevnut
67
Mustang,OK
May 26, 2004
  • May 26, 2004
i have a 91 coupe with 2.73s an a aod. i got a killer deal on a zex nitrous system. i just want to know if the tranny could handle it at all? i dont plan on shottin off the line id shot about 60 foot out all the way to the finish. the car has 101000 on it.
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
May 26, 2004
  • May 26, 2004
you should be fine. definetly should upgrade the torque converter and get a shift kit just to firm up the shifts and make it worth your while
50Dreamer
688
17
38
CT
May 26, 2004
  • May 26, 2004
Depends on the shot your gonna run.
hamonkeiser
290
Lancaster, PA
May 26, 2004
  • May 26, 2004
As long as your run less than a 125 shot you should be fine. I run an Edelbrock system on mine with no problems
trevnut
67
Mustang,OK
May 27, 2004
  • May 27, 2004
i plan on running a 75 or 100 shot. i am going to get a 2800 stall and 3.73s and a shift kit this summer. hope it will pick it up some. wha do you guys think it wil run?
Henceforward
The Avatar Master
485
  • May 27, 2004
Do you need a bottle warmer?
I read that Nitrous Oxide splits at a certain temp, (570 degrees F).
http://auto.howstuffworks.com/question259.htm
So the injection of nitrous oxide into an engine means that more oxygen is available during combustion. Because you have more oxygen, you can also inject more fuel, allowing the same engine to produce more power.
Remember, Nitrous Oxide is NOT FLAMMABLE!
87'GTstang
1,025
  • May 27, 2004
yep, it's a combustion-inhibitor. Just don't over do it. Think of nitrous in an engine like a cannon. Yes it's built very capable, but what happens if you pack too much gun powder in it in an attempt to get a bigger blast (ie: horsepower) and send the cannon ball farther and faster (ie: the piston moving downwards in the combustion cycle) ? Same principle here with the internal combustion engine....
BTW: a high stall converter is for high-revving engines. It gives a highly modified vehicle the abilty to launch higher in the rpm range where it was designed to run at. It's completely in appropriate in the setting of a stock application, you'll be wasting your money and you will be giving your engine a narrow rpm band to work with. Plus you don't have the equipment to run high rpm's in stock form. You can however go for it and you will get some results, but you'll more than likely run out of rpm-band before you can really have a big effect. Hold off on the stall converter until you give your engine some more breathing power. The stock heads make the engine kind of crap out around 5500 rpm's. Definitely go with the 3.73's or maybe even 4.10's and the shift kit however though.
00 Red SS
270
Grain Valley, MO
May 27, 2004
  • May 27, 2004
It really seems to wake up the aod cars, theres 2 here w/ just mufflers gears and slicks running 12.80's and getting quicker from nitrous.
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
what would you do? sell the project and buy completed or finish project?
  • STANG32
  • Feb 8, 2025
1965 - 1973 Classic Mustangs -General/Talk- Feb 16, 2025
rusty428cj
M
  • mnky99
  • Sep 5, 2025
mnky99
M
