NOS Ping
  • Thread starter Thread starter GearHd6
  • Start date Start date Aug 4, 2005
GearHd6
459
Ashford, CT
Aug 4, 2005
  • Aug 4, 2005
I've got a 91 Coupe with 100HP shot of nitrous via an NX wet kit. Timing is at 10* and when shift into 2nd gear with my AOD I get some pinging until the RPM's pull back up. I've got a shifter mounted actuator button rather than the WOT switch, so if I let off the button until the RPM's build back up its fine. Does that sound normal or do I still have to much timing?
Grn92LX
Fidanza Man!
6,819
64
129
New York
Aug 4, 2005
  • Aug 4, 2005
I'd wire up a WOT switch personally.
Clean your maf elements, run 93 gas and pull another 2* out to be safe. What plugs do you run and what gap? Autolite 24's gapped @ .035" should be ideal.
GearHd6
459
Ashford, CT
Aug 4, 2005
  • Aug 4, 2005
Yeah i've got 24's gapped at that. I dont like the WOT switch just for sake of spinning the tires out of the hole. That way I can control when it comes on, if I dont need it and I can beat the competition on motor then I dont have to waste the NOS.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Aug 4, 2005
  • Aug 4, 2005
You run a switch as well to turn the WOT switch on. If the switch is off and you go WOT, your running on motor.
T
TheSlowLX
44
  • Aug 4, 2005
yeah thats how i have it on my car. I have a switch to actually turn on the Nitrous, and have a microswitch on the Throttle. So i can just take off on motor and just flip the switch on..and on comes the nitrous.
GearHd6
459
Ashford, CT
Aug 4, 2005
  • Aug 4, 2005
Yeah I have the arming switch in the ash tray, just not as convienent at the shifter switch. I know enough to only squeeze the button under full throttle. Its an automatic so it doesnt take a brain surgeon, hehe.
GearHd6
459
Ashford, CT
Aug 4, 2005
  • Aug 4, 2005
So I should back my timing down to 8* and run 93 octane and that'll cure the ping?
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
