• Community Forums
  • Regional Forums and Event Information
NOS question
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date Jun 18, 2005
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jun 18, 2005
  • Jun 18, 2005
So do i want to retard my timming from STOCK setting or from the setting i'm currently at? I'm at 12 now? peace
john
loud 95
562
Milwaukie, OR
Jun 18, 2005
  • Jun 18, 2005
Generally speaking, you would want to retard your timing to 10 degrees initial with your kit, while still burning premium fuel to keep detonation under control. Your intructions, with your kit, should give you the specifics of this. Your fuel pressure should be set in accordance with the size jets you are using, as well as what pressure your system is supposed to remain at. If you do not have a bottle heater, I would recommend you save up for one. Systems without heaters see huge fluctuations in bottle pressure, which leads to inconsistent performance. Good luck!
N
Nobody
2,515
Kenmore, WA
Jun 18, 2005
  • Jun 18, 2005
john
Yes. Retard from stock. Advance from there if you feel brave.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jun 19, 2005
  • Jun 19, 2005
No boubt the kit does say 2 degrees for every 50 shot or something like that? cant remember but i was woundering is it retard from STOCK setting or from what i'm at now? I alway's run the highest 92 oct. And yes i have the heater the only thing the kit dont have is the auto bottle opener, wich i'll be getting here soon after the tune /chip/crane box with auto retard deveice! it's loaded so i got it 99% done today,all thats left is the plugs oil water to be put back in! damn 6 month's later and i finaly got off my lazy ass and did it . i'll have picture's here in a few day's of it all in progress! then next weekend will it go KABOOOOOM peace
john
DNA DOA
184
Scappoose
Jun 19, 2005
  • Jun 19, 2005
OOOHHHHH this is gonna be fun!!
Ben
D
D347643
Banned
Jan 28, 2003
1,095
portland, OR
Jun 20, 2005
  • Jun 20, 2005
what compression you running? how big of a shot? Im running 9:1 and a 150 shot and i was told i can keep it at 14 degrees.
Drew
909
239
  • Jun 20, 2005
I'll leave this to the big tuner boys... but since it is a free world to type...
If you currently have your timing retarded for whatever reason, you should pull from where it currently is. Advancing back to stock and then pulling from there would only seem to leave you unprotected from your original issue (bad pump gas maybe) that you retarded for. Right?
The NOS isn't going to build you any buffer to help compenstate for your orignal retard, it needs it's own buffer so I think you should retard 2 degrees for every 50 shot on top of whatever retard you may already have. That would be the safe route anyway. Then as you balls mature and begin to drop, you can try to put your timing back in!
Seriously though, call the NOS tech support line. 3 years ago when I had NOS, I called them and they friggin' answered the phone and had all sorts of information for me. They were pretty awesome back then, maybe they still are today.
Darkness
3,345
Banbury - England
Jun 20, 2005
  • Jun 20, 2005
Just run 2 degree cooler plugs and 10 degrees initial and you'll be more than fine.
loud 95
562
Milwaukie, OR
Jun 21, 2005
  • Jun 21, 2005
Yeah, what Paul said....
N
N20Jnky
721
#10
  • Jun 27, 2005
  • #10
Smoked:
I am always more conservative than necessary but maybe that is why I have (well had) a 11 second 120,000 mile plus stock block AOD car. Here is what I would suggest. 1 or 2 degrees cooler heat range on the plugs and 2* retard for every 50 hp shot. Begin there. Then you can either tune based on reading the plugs, or if it were me, spend the $150 bucks and get it on a dyno and tune the thing there using the wide-band O2.
Start conservative and then work your way up. Be patient and you'll be a bottle freak in no time.
Take care...
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Jun 28, 2005
#11
  • Jun 28, 2005
  • #11
N20Jnky said:
Smoked:
Take care...
thanks a billon but yes i wiull start where you said and take it to Jeff at AFP to do the dyno!!! But first thing's first another new tranny make all the power you want but if it aint movin it aint movin !
NOS Carlite Replacement Windshield
  • Habu135
  • Dec 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
FastDriver
Coupe Rear Glass Cost
  • AeroCoupe
  • Jan 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
AeroCoupe
R
New Member from Poland
  • Restomotive
  • Apr 22, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 22, 2026
91AOD5.0LX
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Pro-M 75MM Bullet Flow Sheet - Is this calibrated for 36 # injectors?
  • dan50
  • Jan 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jan 11, 2026
dan50
  • Community Forums
