Generally speaking, you would want to retard your timing to 10 degrees initial with your kit, while still burning premium fuel to keep detonation under control. Your intructions, with your kit, should give you the specifics of this. Your fuel pressure should be set in accordance with the size jets you are using, as well as what pressure your system is supposed to remain at. If you do not have a bottle heater, I would recommend you save up for one. Systems without heaters see huge fluctuations in bottle pressure, which leads to inconsistent performance. Good luck!
