Not peaking where it should...
  • Thread starter Thread starter Maroon5.0
  • Start date Start date Oct 18, 2004
M
Maroon5.0
57
  • Oct 18, 2004
Hey guys, i rebuilt my motor over the summer and did h/c/i i did crane cam with power range of 1500-5500, performer intake, and gt-40p heads and it only peaked at 4850, my question is do you think it peaked so low because i have the stock throttle body and mass air and at the high of rpm it cant get in the needed air to keep making power? Im really not sure and am trying to figure it out so i can atleast peak in the 53-5500 range like i think it should
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Oct 18, 2004
  • Oct 18, 2004
post the specs on the cam and all that good stuff for more input , MAF and TB could be causes though for sure ......
T
tjm73
2,418
Rush, NY
Oct 18, 2004
  • Oct 18, 2004
Are you looking at the factory tach? If so, forget the numbers as it is notriously inaccurate at higher rpms. I saw over 7000 rpm once in my car and the factory rev limiter never came on. Factory computer limits revs at 6250 rpm, so I was almost 1000 rpm off and still no rev limiter.
M
Maroon5.0
57
  • Oct 18, 2004
no im going off the dyno sheets as to where it peaks
heres specs
Basic Operating RPM Range 2,000-5,500 RPM
Intake Duration 050 inch Lift 216
Exhaust Duration 050 inch Lift 220
Advertised Intake Duration 270
Advertised Exhaust Duration 278
Intake Valve Lift with Factory Rocker Arm Ratio 0.533
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.544
9
90Notch
1,046
Westwood, MA & yes it's killing me that I'm no
Oct 18, 2004
  • Oct 18, 2004
Did you degree the cam? I'm running a stock MAF and stock TB and I'm peaking at 5200rpm. Post your dyno sheet, I've been loking for a dyno of a 2030.
M
Maroon5.0
57
  • Oct 18, 2004
yeah it was degreed in
9
90Notch
1,046
Oct 18, 2004
  • Oct 18, 2004
Small cam that closes intake early isn't going to be high revver. What was your torque?
M
Maroon5.0
57
  • Oct 18, 2004
torque peaked out at 4000 rpm at about 330ft-lbs
TrickStang37
292
  • Oct 19, 2004
my e303 peaked at about 5100 (220*/220* .529/.529 runnin 1.7s) with Street Heat intake, TFS heads, 65mm TB and 73mm MAF. So I dont think it sounds too off, if anything i think sounds about right. If you had to pick between the MAF or the TB holdin you back, i would guess MAF. doubt the TB is holding you back much at all. What was your fuel ratio like? stock fuel pump?
TrickStang37
292
#10
  • Oct 19, 2004
  • #10
BTW, not all factory tachs are off. Mine was off by about 50 or so RPMs vs my Autometer tach at fuel cut off so i ended up taking out the Autometer.
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Engine Popping noise in the intake. Frustrated still.
  • esteban31065
  • Apr 6, 2025
Fox 5.0 Mustang Tech May 23, 2025
gkomo
A
SOLD For Sale: 1993 Ford Mustang Cobra Modified
  • anjteal93
  • Sep 5, 2025
2K
Fox Body Mustangs For Sale (1979-93) Oct 26, 2025
Mindseye007
E
1986 Convertable 5.0 GT
  • eneerg
  • Sep 24, 2025
  • The Welcome Wagon
The Welcome Wagon Sep 24, 2025
