So I have reinstalled the trans and clutch two times now and am still messing it up somehow. Hoping someone here can help me....
I started many months ago with putting in a new clutch, motor/tranny mounts, exhaust and various other little things. The first time I put everything back together I messed up the oil pan gasket and had a very bad oil leak. I also had a bad clutch (chattering?) noise. So I had to take it all back apart and start over. I just finished putting everything back together again and have still more issues. I am now leaking transmission fluid where the trans bolts up to the bell housing. And I still have a bad clutch noise. What's odd about the clutch noise is that it didn't happen right away. I actually drove the car about 50 yards down the street and back and didn't have a problem, and then it started to get hard to put into gear and then the noise started. Sounds like a rubbing/grinding type of noise. I tried adjusting the cable many different ways and sometimes it would make the noise worse but it never really got better. The way it was before I just took it back apart, with your foot off the clutch there was no noise, but as you started to push the clutch pedal it would just start making a racket. And once again, I let the car sit for a while and then I was able to get it in gear and drive it back into the garage and then the noise started as I got it in there. I took pictures of all the different pieces.... this is my first time doing any of this and to me everything looks fine. The car only has about 45K original miles on it and all the clutch pieces are brand new from LRS. I also replaced the input shaft retainer and when I took it off after getting the transmission back out it was full of fluid... I'm guessing that's why I was leaking the trans fluid.... Can anyone suggest anything that will help me get this back together? Below are pictures of everything... does anything look off? I've read the clutch install articles/videos on the web but obviously I'm still messing it up somehow.... thanks for any help!
