Hey guys, I have a 2007 GT convertible. Top won’t go up. It has 2 new hydrolic cylinders, both the relays are clicking, and I just replaced and filled the top motor. Any ideas?
Dave!
I'm having the exact same problem with my 07 GT vert. I disconnected the hydraulic rams so I could at least put the top up. Did you ever find the problem? My relays under the hood click. I tried swapping them. No luck. All fuses are good. When I try to raise or lower the top with the engine running, the engine dies. Now I just found out when I turn the headlights on, the engine dies. obviously an electrical gremlin. I'm thinking a bad ground. Just wondering if you ever found the problem and might help me. Thanks! BTW, what color is your stang?
