Just figured I'd let you guys know all the fun you you're missing out on
I spun some bearings, reground the crankshaft, installed new bearings, got it back together only to find something knocking above 2000 rpm. And another unrelated problem...my speedometer goes crazy. Sitting still it'll shoot up to 150 and the odometer will run, then the needle goes all over the place. Checked the connectors and didn't notice anything abnormal. Don't know how any of that's related or if it's some sick joke this car's playing on me again. Starting to really hate this car.
Anyway, took the engine back out thinking something for sure happened to the new rod or main bearings. They ended up being all ok. So then I checked the timing. Somehow one side jumped a tooth (1 tooth retarded). I don't know if I messed up even though I remember tripple checking it. I'm guessing it happened when the tensioner wasn't all the loaded or something. So then thinking I probably destroyed my valves, I was doing some leakdown tests. All the valves are fine but found excessive blowby on one of the pistons. Took the piston out and the ring lands are shattered. Explains the slight miss this thing had before...
Anyone know a good place to get a stock oversize piston and rings? I've not measured yet but I think these are bored a size over.
I looked on directfordpars.com but they don't mention anything about oversize. They list 3 different grades and say "order by grade" Is that "grades" of oversize and how do you know what's what. Also, the rings only list one size.
