Google charcoal canister for your year stang, you should find parts, vacuum routing and a wire harness with a solenoid, basic explanation is it regulates fuel tank vapors with manifold vacuum. You need to fix this.
Definitely a big vacuum leak... I had a similar problem when one of the caps on the metal line next to the carbon canister feed deteriorated enough to be ineffective. I had an idle that ran at 1000 RPM no matter what I did to try and fix it.Well I found that the hose running from the purge solenoid to the canister is missing. Hopefully this will fix some problems. I would imagine this is a big vacuum leak?![]()
It's fixed! Thank you guys for all the help! Much appreciated. I do still have a few things to do and some questions. So I replaced my distributor but I kinda messed up. I used to run timing at 14* well now I could only get 10* because I cant get my dist to turn anymore.
You are 1 tooth off and it won't hurt anything except you can't turn the distributor enough to set the timing at 14°.It's fixed! Thank you guys for all the help! Much appreciated. I do still have a few things to do and some questions. So I replaced my distributor but I kinda messed up. I used to run timing at 14* well now I could only get 10* because I cant get my dist to turn anymore.
NoCould I just hold the rotor in place. Pick up the distributor a little bit and turn the housing?
, WOT the car just falls on its face at like 3-3500 rpm. Will rev past that in neutral and if I ease into it like 1/4 throttle it will go past as well. Any ideas?
Appreciate the input. I have a brand new tfi and distributor in. Ran good until I decided to fix my timing issueHigh speed miss on a warm engine
Revised 7 Nov-2016 to add PIP sensor as possible problem and dumping the codes to help determine if it is the TFI or PIP.
The TFI module mounted on the distributor is one of the culprits for a high speed miss on a warm engine. The other suspect is the PIP sensor inside the distributor. If the problem does not occur when the engine is cold, the TFI module or PIP is definitely suspect. Dumping the codes may help determine which one it is. You may need a special socket to remove the TFI module, but most auto parts stores will have one for $5-$7.
Be sure to use plenty of the heat sink grease on the new TFI and clean the old grease off the distributor.
See Automotive Tools Specialty | Auto Mechanic & Technician Diagnostic, Testing Equipment | Thexton
diagram courtesy of Tmoss & Stang&2Birds
So does the problem happen with a cold engine?Appreciate the input. I have a brand new tfi and distributor in. Ran good until I decided to fix my timing issue
