Well since i've been driving the car now my turn signals dont work.The hazards flash and make the click sound, but either way i turn on the turn signals ,neither direction works. I looked at the switch today and everything is hooked up and nothing is loose and all the other functions of the multi function switch works. I did notice today tho, that with the key out of the ignition i can turn on the hazards and when i turn the left or right turn signal on the hazards stop and only the left signal blinks.But as soon as i turn the turn signal off the hazards work,OR if i turn off the hazards off they stop.If the turn signal part of the multi function switch is messed up would it cause the turn signals not to work and to make them do what they are doing with the hazards on?My girlfriends 2000 expi does the same thing with the hazards on with the key off when you turn on the left or right turn signal,but her turn signals work fine as do her 4ways.But my 92 coupe dosent do this. Whats got me and i think is weird is my 89 and my girl friend expi does this with the key out of the ignition,but my coupe dont. peace
john
john
peace
went out and checked what you said about making sure the harness's were connected to the back of the hazard switch ID89GT.And well 2 of the wires on the big connecter wasent plugged into the connector,they got pulled out of the connector when the dash swap was done.I plugged them in and everything is good!I read your post in here and after you said that i remembered that you need both connector's plugged into the hazard switch,cause me and a buddy did a florida 5.0 cluster swap and we werent sure we needed both those connectors plugged in. peace
