My baby is finally going to be complete. The car is going in the shop for the engine work in a month, as most of the parts are already shipped or ordered. As time gets near, for my engine work, i'm getting a little impatient and i can't wait to see what my car will do on the track and on the dyno. So I wanted to compile a list of the parts i already have or are about to order to see if you guys could give me an estimate of my 1/4 time/hp numbers. Also, as you can see, I've put a lot of time in researching this project, and I'm about to spend a lot of money on this vehicle, so if you think I'm missing something, let me know. I appreciate the help in advance.
Vortech V-2 SQ Supercharger w/ Aftercooler System
VT Stage II Cylinder Heads
VT Stage III Blower Cams
Manley Lifters
Cobra Forged Crank
Manley H Beam Forged Rods
Manley Forged Pistons - .30 over
Moly Rings
FM Bearings
ARP Main and Head Studs
Head Gaskets, valve cover gaskets, intake manifold gaskets, exhaust manifold gaskets, timing cover gaskets, front seal, rear main seal, water pump o ring, oil pan gasket
Oil Galley Plugs
Crank Damper Bolt
BBK L/T's
BBK Catted H Pipe
BBK 75MM Throttle Body
42# Injectors
Vortech 255LPH Fuel Pump
3.73's
B&M Holeshot 3000 Torque Converter
FRPP Tranny Cooler
Custom Tune by JDM Engineering
So put your thinking caps on and help me out, lol. Thanks again guys.
Oh and btw, the only things I didn't order yet were the pistons and the heads. They will be getting ordered in the next week.
Manley Lifters
Cobra Forged Crank
Moly Rings
FM Bearings
Oil Galley Plugs
Crank Damper Bolt
BBK L/T's
BBK Catted H Pipe
42# Injectors
3.73's
FRPP Tranny Cooler
