  • 1994 - 1995 Specific Tech
numbers###
  • Thread starter Thread starter DDSTANG94
  • Start date Start date Aug 31, 2007
DDSTANG94
465
FRASER, MICHIGAN
Aug 31, 2007
  • Aug 31, 2007
what kind of rear wheel power numbers would i put down with a kenne Bell and AFR 165's with the supporting mods on a 94 GT?? .. My guess is 400 the wheels tops.....but i dont want anymore then that because of reliability issues. Also kind of boost would i put down with that the heads there...???
THANKS GUYS
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Aug 31, 2007
  • Aug 31, 2007
THANKS GUYS
400 or a bit less sounds like the range you could expect
I don't know the answer to your boost Q
but
I'm gonna have you think about that Q a bit with these thoughts
Consider this about boost and the amount you might see on a gauge
Say you have a stocker Stang and you put out 10lbs
Take that same Stang and install h/c/i and all supporting mods
with the same blower setup.
The motor has become more efficient
and
You will now see less than 10lbs
Is that good or bad
Where I'm going with this is
amount of boost is not totally indicative of making horse power
Also ... with a KB ... the small blower can run outta breath if you got it all
setup with h/c/i
Grady
DDSTANG94
465
FRASER, MICHIGAN
Sep 1, 2007
  • Sep 1, 2007
i got ya Grady, it will see less boost with them heads because there will be less "pressure" in the engine, its not as restrictive.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Sep 1, 2007
  • Sep 1, 2007
That is exactly where I was going
Now ... if say you could bring back up that combo with h/c/i to 10lbs again
and
The blower was still in its effective range of output
Well ... thats just a different way to show
10lbs is not just 10lbs in different combos
Thats why you see a lot of the time
a guy has a good bit of boost on a stocker ......
its so restrictive
Grady
Killercanary
The car that set the bar.
Altoona, PA
Sep 1, 2007
  • Sep 1, 2007
THANKS GUYS
My cousin made 396rwhp with 6lbs of boost on a stock bottom end '94 with an FTI custom cam and a holley systemax I lower intake. he has since switched to a GT40 lower with a flowzilla manifold, but he hasn't re-dyno'd the car. With his "old" combo I lit the tires up in 3rd gear at around 75mph... it was one white knuckle drive I never want to have again.
SVT3183
180
S Jersey
Sep 2, 2007
  • Sep 2, 2007
i made 330/380 at 7# with my KB 1.7 and a completely stock cobra motor. i'm throwing on 165 ped mount and a tmoss ported lower in a few weeks so i guess i'll see what the increase is. i don's see why this and a good cam couldn't easily get you to 400. i'm hoping to be around there with the stock cam.
Does anyone else have a combo close to this
  • 90Stanger302
  • Dec 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 25, 2025
Qtrhrse23
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
What's it Worth? 2000 GT
  • Mustang5L5
  • May 8, 2026
What is it Worth?!?!? Jun 13, 2026
KRUISR
