O/R H-pipe
  • Thread starter Thread starter RedFox5.0
  • Start date Start date May 19, 2007
R
RedFox5.0
PA
May 19, 2007
  • May 19, 2007
I recently bought an O/R H-pipe. I found out that if I don't have the o2 override plugs that my cars computer will make it run like crap. Now what I want to know is:
How much of an HP gain do you even get with and H-pipe and O2 plugs?
Should I just take it back? My car already sounds alright.
Where to get O2 override plugs?
EPIK
796
LEFT COAST
May 19, 2007
  • May 19, 2007
I think u are reffering to the MIL eliminators. U can get them @ American Muscle, or check your local Mustang shop if u dont want to wait. Just keep the H, because u will gain a little top end hp, & you will see, your car will sound SICK!!!
Check these out. This is what u will need.
http://www.americanmuscle.com/stmilel.html
R
RedFox5.0
PA
May 19, 2007
  • May 19, 2007
I don't know,, I'm not sure if I should keep it. I have emissions in my County so I will have to rip it out every year. I know no one who would pass it. I'm thinking I should maybe send it back and get either 3.73 or 4.10's for it instead. I would probably benefit from the gears more.
EPIK
796
LEFT COAST
May 19, 2007
  • May 19, 2007
Your are right about the gears giving u more of a benefit on a near stock 98 GT. The H will give u a little bit more top end HP & make your car sound sick though.
D
Dragstr05
643
Stafford VA
May 19, 2007
  • May 19, 2007
The sound is sooo worth it man. Technically, with the MIL's your car *would* pass inspection so long as you can get it to pass the visual part. The OBDII test wouldnt know the wiser. Just gotta see if you cant find someone and see if they'll pass it on the visual for a little somethin.
Even if you have to swap it once a year, its NOT that difficult. Gears will cost you 2-3 times as much but I hear they are worth the cost.
P
postalbunny
118
May 20, 2007
  • May 20, 2007
H pipe will sound better, gears will be about 3x as much fun. I'd do gears first.
Twista
510
@ the z00 in chicago
May 20, 2007
  • May 20, 2007
O/R pipes on a 96-98 near stock NONPI is going to make you even slower. You know why? Because up high is where 4.6's see power, but on the non pi's up high is where you run out of breathe. 96-98 stock makes the best power they can make down low and removing that back pressure down low is killing all the good power we can make with our heads/intake/cams. For the sound its worth it b/c with cats or w/o the nonpi is still a dog. Just drive it like your cruising... Jeep Grand Cherokees will be able to take you off the line, so cruise like your not trying. Tons of cars can take me off the line with my car trying ;[ , but hey i sound alot better than theres ;]
Also, i been running my car w/o mils since i got the o/r pipe and i dont see any problems. Every so often i have to unplug the negative cable for 15-30 minutes to get rid of the CEL.
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
