o ring'd head question
  • Thread starter Thread starter Modular2v
  • Start date Start date Nov 10, 2006
Modular2v
3,222
23
99
oklahoma
Nov 10, 2006
  • Nov 10, 2006
What all will i have to modify to run a set of o ring'd heads? Or is is just simply finding steel rings to put in the slots?
D
Daggar
3,902
  • Nov 10, 2006
Steel rings or a set of gaskets with the wire already in them.
-or-
I think you can run MLS gaskets with those just like they were not o-ringed at all. Double check this last suggestion with some other folks though. It's something that I've "heard" of being done but not seen.
Modular2v
3,222
23
99
oklahoma
Nov 10, 2006
  • Nov 10, 2006
-or-
Thanks dagger. . . i was just making sure i wasnt buying a set of heads that i would had to have had the block machined in order to work with them
TC93
Well-Known Member
Sep 11, 2000
2,075
Ellerslie GA 31807
Nov 10, 2006
  • Nov 10, 2006
Depends on what the heads were machined for, either the wire or for the o-ringed gaskets. Just had a set of heads machned for o-ringed gaskets(fel pro 1006). Machine work is different between using o-ringed gaskets or using the ring in the head or block with copper gaskets.
Modular2v
3,222
23
99
oklahoma
Nov 10, 2006
  • Nov 10, 2006
They are the trick flow o ring'd heads
Sicarius428
2,085
Nov 10, 2006
  • Nov 10, 2006
I am running TFS o-ringed heads and nothing needed to be done to the block. The gaskets are what has the o-ring. You should be good.
Kevin
Modular2v
3,222
23
99
oklahoma
Nov 10, 2006
  • Nov 10, 2006
Kevin
Thanks for easing my mind guys
Modular2v
3,222
23
99
oklahoma
Nov 10, 2006
  • Nov 10, 2006
Kevin
do you mind me asking what gaskets you run? I need something that will stand up to the nitrous
Sicarius428
2,085
Nov 10, 2006
  • Nov 10, 2006
I just bought the gasket kit for the TFS o-ringed heads from summit.
http://store.summitracing.com/partd...908331+4294924929+4294840126+115&autoview=sku
There is another gasket set for the high ports.
Kevin
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
Teflon O-ring for power steering
  • revhead347
  • Feb 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
revhead347
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
