  • SN95 4.6L Mustang Tech
o2 sensor extensions
  • Thread starter Thread starter 87 blown stang
  • Start date Start date Dec 7, 2004
87 blown stang
139
pa
Dec 7, 2004
  • Dec 7, 2004
ok my prochamber is on it's way. will i need extensions? or can i just lengthen mine? i wasn't sure if one i need to do this or two i would screw up the function of the sensor by splicing. of course i would solder and heat shrink. any suggestions?
Milenko
Skid Mark Layer...only not fro
462
Boston, MA
Dec 7, 2004
  • Dec 7, 2004
If you need to extend them I believe that soldering and heat shrinking would be fine. I don't see any reason why extending them would have an effect on the readings.
Silvr04GT
1,131
San Jose, CA
Dec 7, 2004
  • Dec 7, 2004
Is that a for sure thing? Is the position of the O2 sensors in the 04s different than 99 - 03? Cause I just got my MagnaFlow X-Pipe and I wanna know before I get it installed.
Milenko
462
Boston, MA
Dec 8, 2004
  • Dec 8, 2004
I'm not sure. I don't see why there would be a difference though.
madstyle1
21
  • Dec 8, 2004
Actually, when i got my prochamber i had to get extensions and my friend just soldered it and heat shrink it and it work... the Service light turned off. the location on the 04 is different on than the 99-03.. just a heads up!!
Z
zcs626
260
dallas
Dec 8, 2004
  • Dec 8, 2004
yup 99-03's its closer towards the exhaust manifold. on the 04's its futher away.
ill probably just solder/heat shrink instead of buying the extenders (35 or so dollars )
Silvr04GT
1,131
San Jose, CA
Dec 8, 2004
  • Dec 8, 2004
Where do you get these extensions from? Do they sell them online anywhere?
propellerhead
1,541
"but what's with the but shots?"
Dec 8, 2004
  • Dec 8, 2004
They are everywhere. www.dallasmustang.com, part number DMP-Part#: 8531.
Marks5.0!
640
San Antonio, TX
Dec 8, 2004
  • Dec 8, 2004
thats where mine came from
DarkFireGT
Playing with my wife's really makes me want one.
692
10
89
East Moline, IL
Dec 8, 2004
#10
  • Dec 8, 2004
  • #10
be careful if you have an '03. ford is notorious for putting new parts on the last year of the old parts.. my '03 needed the drivers front extended. I just spliced in some wire and shrink tubed it.
merc123
420
North GA
Dec 8, 2004
#11
  • Dec 8, 2004
  • #11
These extenders, aren't they just MIL eliminators? Something you want to buy anyhow to turn off the CEL? My driver's side bank O2 sensor was a bit short. I got it plugged in but it was really tight. After I got the MIL eliminiators put on I had no problems.
propellerhead
1,541
Dec 8, 2004
#12
  • Dec 8, 2004
  • #12
Huh?
propellerhead
1,541
Dec 8, 2004
#13
  • Dec 8, 2004
  • #13
Those are different from the MIL Eliminators. The stock H pipe on the 04s are a little different. I don't know why.
87 blown stang
139
pa
Dec 8, 2004
#14
  • Dec 8, 2004
  • #14
you won't need mils if you have acess to a programmer. i'm running the diablo pred. that was the one initial perc. was not needing mils, speed sensor thingy(gears), timing adj. etc
I
injectedracing
60
springfield, mo
Dec 8, 2004
#15
  • Dec 8, 2004
  • #15
either extend the wires yourself, or spend the money on extenders. Ive extended many O2's this way. If you have a predator, then turn the MIL off that way.
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
M
Electrical lights
  • Magnet86
  • Sep 11, 2026
Fox 5.0 Mustang Tech Sep 14, 2026
Magnet86
M
