Can someone get me the o2 sensor file or picture of what the wiring should look like, someone spliced wire together on my car and it dosent look right to me, worked fine, im just unsure.
Josh, it's kinda hard to make heads or tails of it since 3 wires are the same color on the O2 sensor itself IIRC (JR was kind enough to help me with a little project a little while back, and I was under there farting around).
I can dig out the EVTM for my '94 if it will help ya. I do recall referencing it vs. the AZ stuff and for what I was doing, both matched up in synch.
Good luck.
EDIT: DOH - it looks like you have an '86. Nevermind. Between your username and sig, it's not easily clear what you drive.
lol oh my bad!! yeah I have a 86 gt, with a 93 gt harness, converted mass air, blah blah, mine has alot of spilced wires, but it works fine, so if you can get the file that would be great just to verify.
If you were talkin to me, I actually don't have any info to help. With the wealth of fox III schematics (many thanks to Tom and others) available online, I haven't had a need for a Fox III EVTM. Info for 94-95's is much more scarce, so those are the years for which I have more reference materials.
Generically, this diagram (note that it's not year-specific for your application) might provide a ballpark idea (some wiring colors changed over the years and some didn't). A diagram like this is how I interpret what wire does what, since on my car the wires were homogenously colored (I clocked the connector and went around it clockwise, to compare it to the wires to what the schematic showed).
