O2 sensor signal wire
stevesLX
373
cincinnati
I picked up a Air to Fuel Ratio guage today. The one wire on the guage needs to hook to the O2 sensor signal wire coming off the computer. Does anyone know what color I am looking for here or what pin #?
The A/F gauges that use the O2 sensor signal will jump all over the place. The reason is that the O2 sensors "switch" between .2 volt lean and .6 volt rich with a curve that looks like the drop off a high cliff. The curve is almost straight up and down, so the voltage shoots from .2 to .6 and back down . again 2 or more times a second at cruse. You won't get much useful information except when the mixture is extremely lean or extremely rich, there is no middle ground.
Use 43 (Dark Blue/Lt Green wire) or pin 29 (Dark Green/Pink wire ) on the computer. Use Wire tap-ins from Radio shack P/N 64-3052. The computer is located under the passenger side kick panel. That keeps you from having to crawl under the car and make a weather proof splice in the wiring. You can use either one, or run a SPDT switch and use both. Then you can use the switch to select which side to view.
attachment.php
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
Computer, actuator & sensor wiring
AutoZone wiring diagrams
http://www.autozone.com/az/cds/en_us/0900823d/80/16/71/3c/0900823d8016713c/repairInfoPages.htm for 79-88 model Mustangs
http://www.autozone.com/az/cds/en_us/0900823d/80/19/59/5a/0900823d8019595a/repairInfoPages.htm for 89-93 model Mustangs
http://www.autozone.com/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c/repairInfoPages.htm for 94-98 model Mustangs
