  • 1994 - 1995 Specific Tech
O2 sensors reading LEAN
  • Thread starter Thread starter mustbastang
  • Start date Start date Aug 7, 2005
mustbastang
10
NJ
Aug 7, 2005
  • Aug 7, 2005
ok here is the skinny, i had a blown head gasket so when i fix the head gaskets i made a few changes. i changed my performer intake to track heat and i installed BBK short but equal headers, now my O2s r reading lean. my LM-1 wide band is reading a A/F at PT between 13.5 and 15.2 now at WOT i am reading 10.7 and 11.4. now after 4000 rpm at WOT the car bogs down, i replaced the driver side O2 and the reading on my PMS tuner is still reading lean could the headers be causing this problem.
thanks for the help
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Aug 7, 2005
  • Aug 7, 2005
Why the small fuel pump on a blown car?
As for the part throttle ratio range
If your load is not too great, then your in closed loop and a ratio that jumps around like that is not that uncommon. It just depends on how far off the tune is which determines how much the adaptive strategy is working to + or - the ratio with its attempt to give you 14.7
I'm a bit confused about the last 25% of your post but if I understand correctly, it looks like your too fat in open loop or wot.
Whatever you do to adjust the ratio with your PMS, I'd do it in small steps and use your wb to verify those small changes are helping. Don't wanna go the wrong way but if you happen to do it, since the adjustment is small, it ain't gonna do no harm, lol.
btw, might wanna dial the spark back a bit to be safe or you might be in the market for some new head gaskets.
Later
Grady
must b a stang
48
  • Aug 7, 2005
final5-0 thanks for the response, i still have to change the fuel pump, i am going with a 255lph. as for the tune my car is giving me 2 codes 1 is bank 2 lean and the second is bank 1 lean.
Zero Signal
2,633
Tucson, AZ
Aug 7, 2005
  • Aug 7, 2005
So, wait your post says lean, the numbers you put there say rich. 13.5 to 15 ish should be fine for part throttle. You want it aorund 14.7 so i'd say you're fine there. But the 10.7 and 11.4 are waay rich for an N/A motor.
Are you refering to commanded AFR?
Mathulus
14
Lowell, MA
Aug 8, 2005
  • Aug 8, 2005
his car is s/c not n/a
mustbastang
10
NJ
Aug 8, 2005
  • Aug 8, 2005
I believe i have found the problem, the lower intake right under the t-stat housing seams to be leaking oil, after i posted i noticed an oil puddle in that area. i ordered new gaskets and i will due repair on wenesday. i hope this solves the problem.
AznStanger3v
2,026
Northern VA
Aug 8, 2005
  • Aug 8, 2005
10.7 to 11.4 on a blown car are good numbers. and even for peak performance, stoiciometry isnt ideal, na or not. 14.7 is a number for the most efficient, emission friendly burn.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Aug 8, 2005
  • Aug 8, 2005
Allan
I don't have any issues with what you are saying.
Your post did make think of some additional things however
Some things are still not clear to me about this thread but ...........
It looks like to me and I'd have to say that, by what Zero Signal posted.......
mustbastang is talking about two separate conditions of closed & open loop.
He uses "PT" and I'm gonna believe that is part throttle. Here is what bothers me about that ...........................
Part throttle may or may not be in closed loop due to our cars are load driven from the pcm's perspective. The range of 13.5 to 15.2 he talks about .........
my concerns would be for when he is seeing those ratio values are:
closed or open loop
amount of boost
amount of load
if he is in open loop he just might be too lean
I do wanna point out that I've had no experience with forced tuning but I've thought about it a good bit. Still, general basics would apply and I'd wanna know the above stuff.
I sure his PMS can tell him that stuff.
I'm through thinkin out loud now
Later
Grady
mustbastang
10
NJ
Aug 8, 2005
  • Aug 8, 2005
i am assuming im in open loop because my O2 sensors are reading .04 on driver side and .20 on passenger side, i replaced the driver side but got the same reading. the PMS dose not tell me if im in open loop or closed loop. my LM-1 sensor is not near the stock O2 location, it is locaded apprx. 3" from where H-pipe bends up towards header and it reads fine.
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
Engine Multiple o2 sensor codes, car runs terrible
  • 02newedge
  • Jun 12, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 19, 2025
squeak93
L
2004 Mustang Oxygen (O2) Sensor Issue
  • letumeternum
  • Dec 30, 2024
Lexiii12
L
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
