  • SN95 4.6L Mustang Tech
O2 SENSORS
  • Thread starter Thread starter mr-mike
  • Start date Start date Apr 27, 2007
M
mr-mike
122
  • Apr 27, 2007
First off thanks to the guys who posted with the help on code po136 & where the banks are located , anyway I met a guy who said dont be ina big hurry to throw away $$$$ on new sensors ! they last a long time he said take then out have a look clean them good & try them again ... they were the back ones & easy to remove they were not all that dirty so I buffed them with a fine wheel buffer , sprayed them with some throttle cleaner , cleaned the wire conectors good also , put a dab of antizeez on the threads ..... reinstalled the senors which have over 100,000 miles & she is running like new no more codes ... I KNOW THE BOOKS SAY NEVER SPRAY ANYTHING ON THEM ! well it worked , so just thought I would pass it on as its an easy fix & that guy who gave me the idea said 90% of the time they just need a cleaning & has seen cars with 250,000 miles with the original 02 sensors , so much for the adds that say change them every 75,000 miles ............ PS the auto-store guys were of O-help couldnt even find the right ones for my car & prices for $53 to $73 long leads short leads & other nonsense so thats why I gave cleaning them a try , hope this helps ....
RandyStinchcomb
1,159
Randallstown, Md
Apr 27, 2007
  • Apr 27, 2007
total , when they foul (just like sparkplugs) there fouled, there done. don't be cheap, buy new OEM ones and have no worries about cleaning O2 sensors, what a joke
also the rear ones are NOT Oxygen Sensors, they are Monitors to sea how the cats are working and most of you dont even run catted pipes anyway and the aft Monitors have really NO effect on performance
Shiroelex
There's nothing worse than aut
728
Westland, MI
Apr 27, 2007
  • Apr 27, 2007
I thought that if they trigger the CEL for Catalyst efficiency below threshold, that it put your computer in open loop mode. It's just something I heard, and I thought my car felt different when my current MIL eliminators messed up on me once.
I've always been told to use nothing but air to clean a MAF sensor, and an o2. I've used a 'sensor safe' cleaner once before on my Focus' MAF, and it's never ran right since.
RandyStinchcomb
1,159
Randallstown, Md
Apr 27, 2007
  • Apr 27, 2007
yes it will throw a MIL, never heard about the O/L mode for monitors and I dont think it will affect performance that much, not like a problem wth the O2's would
where's Mike at
R
RoadconeTuning
458
Upstate, SC
Apr 27, 2007
  • Apr 27, 2007
you can use electrical contact cleaner on the MAF sensor with no problems, using TB cleaner will leave trash on there...
as for open loop, that would be really dumb... ford wouldnt not have ti go into open loop and cause it to dump fuel like that, fi anything it would just overheat the cats and give you bad gas milage and cause a lot more pollution...
the CEL you get for the rear "O2" sensors is very minor... dont worry about it, get mils or a tune to fix it.
M
mr-mike
122
  • Apr 27, 2007
randydandy
I knew when I posted I would get one randydandy type copy & paste ! but your post about being cheap means nothing as it wasnt meant for you but I cant let guys like you get away with being so this is for the decent guys so Randy have a nice day all praise to Allah Randy , now you may post anything as I wont answer thanks to the guys who helped & Randy get a life
screamin gt
5 Year Member
Apr 9, 2007
393
central CT
Apr 27, 2007
  • Apr 27, 2007
normally I'd stay out of such an emotional debate but....
if the worst case scenario is someone whos sensor failed needs to buy new ones, then who cares if they try to clean them first? might as well give it a try, worst case get new ones if it doesn't work. just my .02
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
T
What's it Worth? 2002 GT conv/auto
  • tonydetesta
  • Jan 7, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jan 21, 2026
Mustang5L5
J
Car Diagnosis
  • j.2016
  • Aug 31, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 31, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
