quick question...on my 88 LX i have gone though everything fuel related...
pump, filter, lines, injectors, fuel rail.. and plugs, wires, cap, rotor, coil, IAC(idels better after warms up) and i still has a miss...i was wondering if bad O2 sensors could cause a very bad miss when you go to rev it along with it loading up...like i will go to rev it..1/2 throttle and you can hear it suck air and start to die let off and it will stay running..idles perfect after it warms up for a few mins along with getting better about revving..REALLY have to lean into it very slowly to get them up there though...
and the timing is set at 10*
only thing i can think of is..02 sensors(?) dis(?) computer(????)
i know i need to try and pull codes and im in the process of doing that but...i plug the scanner in and it wont light up..works fine on the other 5.0
