o2 siezed, looking for removal tricks.
  • Thread starter Thread starter FiveO
  • Start date Start date Mar 19, 2007
FiveO
1,146
NJ
Mar 19, 2007
  • Mar 19, 2007
i have a siezed o2 sensor and i've done just about everything besides taking a torch to it to remove it. i fear i could mess up the bung if i use a torch, maybe someone can tell me a good way to do it with a torch so that i dont? anyone have any suggestions?
i've done a large wrench...(with cheater as far as i can go before rounding). also used tons of penetrating fluids.
Also the threads on the other side are a little messed up...the new o2 sensor i have wants to thread in sideways. anyone know the thread specs on the bungs on a stock/offroad hpipe? so that i can rethread or chase the threads.
JChalfan
551
Bellevue, WA
Mar 19, 2007
  • Mar 19, 2007
If you are just using a propane torch, there's no way you can screw up the bung, it won't get hot enough. Just take a propane torch and get the bung as hot as you can. Then put your wrench on it, apply pressure, and slowly but steadily increase the amount of pressure you are putting on it. That way you avoid rounding it. Heat can do amazing things when you have a stuck nut/bolt/o2 sensor.
Good luck.
Jeff
FiveO
1,146
NJ
Mar 19, 2007
  • Mar 19, 2007
acutally i used a propane torch, but i was under the car and it was awkward. i guess i can give it a go again. i do have access to a cutting torch but i can change the handle to use it for heating up.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 19, 2007
  • Mar 19, 2007
Heat the bung with a torch, then pour ICE cold water over the O2 sensor. The sudden change in temp will cause the O2 sensor to shrink a few thousands of an inch. Be ready with the wrench to take advantage of the shrunken O2 sensor, because it won't stay shrunken for very long.
FiveO
1,146
NJ
Mar 19, 2007
  • Mar 19, 2007
managed to get the hpipe out by cutting the o2 sensor off...now it should be a lot easier removing whats left. thanks for the input guys.
HISSIN50
34
129
Mar 19, 2007
  • Mar 19, 2007
I guess I missed something. I disconnected the electrical connectors and removed the pipe. Then I could fart around with the O2's with the pipe out of the car.
Anyhow, glad to hear you got it.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Mar 19, 2007
  • Mar 19, 2007
for anyone having problems and trashed the bung, they sell replacement bungs on summit you just weld on.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Mar 19, 2007
  • Mar 19, 2007
shops often stock them too.....I bought a Matco o2 sensor wrench....works awsome
FiveO
1,146
NJ
Mar 19, 2007
  • Mar 19, 2007
i have a o2 sensor socket...it has a split down it for the wire. because of the split it warps on the seized o2s.
the o2 sensor spot on my o/r hpipe happens to sit so that i can't easily access the header nuts. but on the stock hpipe it wasn't a problem. im hoping i can just chase the threads and fix the issue without welding in new bungs.
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Mar 19, 2007
#10
  • Mar 19, 2007
  • #10
is it a cheep socket you have....I can put a long bar on mine and it won't expand
Sicarius428
2,085
Mar 20, 2007
#11
  • Mar 20, 2007
  • #11
I just use the box end of I think a 7/8ths(i think) wrench. The connector slides right through the hole in the wrench and I get a good grip on all the sides of the O2.
Kevin
JChalfan
551
Bellevue, WA
Mar 20, 2007
#12
  • Mar 20, 2007
  • #12
It's incredible the difference between cheap tools and expensive tools. They look the same, but the expensive ones don't warp or distort. Not long ago I tried 3 or so flare-nut wrenches on my brake line, and they all tried to stretch and round it. Finally I went and borrowed a snap-on one from my friend, and it worked awesome.
Too bad I'm too poor to buy a nice set of tools.
kpack5982
Yeah, it was pretty stiff, but eventually a buddy
Jul 13, 2005
325
Granger, IA
Mar 20, 2007
#13
  • Mar 20, 2007
  • #13
I just got mine and I used something called PB. Stuff works WONDERS!!!
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
K
Exhaust Manifold Questions
  • KingSaturn
  • Jan 29, 2024
  • 2.3L (N/A & Turbo) Tech
3K
2.3L (N/A & Turbo) Tech Feb 3, 2024
KingSaturn
K
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
