  • SN95 V6 Mustang Tech
OBDII code- P1505 HELP!!!
  • Thread starter Thread starter JoshuaWCU
  • Start date Start date Dec 21, 2010
JoshuaWCU
  • Dec 21, 2010
Hey guys!! I have a 94 ford mustang 3.8 5 speed, I hooked up my OBDII code checker (yes my 94 is one of the few that is OBDII I guess lol) the code and only code that was given was p1505, but I looked in the manual and none of the codes given start with a 1 like mine does, all start with a 0. Please help me to find out what this code means! Thanks sooooo much!!!
JoshuaWCU
  • Dec 21, 2010
Does it have something to do with the Idle Air Control Valve??? Hoping so, looks like a 60 dollar fix for a new one. HELP!! Thanks!
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Dec 22, 2010
  • Dec 22, 2010
First look for any vacuum leaks. Check the throttle return springs.
Does the car idle fast or slow? How does it run?
This could be a bad IAC or TPS.
JoshuaWCU
  • Dec 22, 2010
Thanks for the reply! Well its hasnt done this in a while now but it used to idle around 2,000 when I would stop at a light etc etc, but it stopped months ago for some reason. The car seems to be running fine but does have a BBK throttle body and cold air. Maybe that has something to do with it? Not sure.
1987LXragtop
837
Just outside Philly PA
Jan 7, 2011
  • Jan 7, 2011
x2
Engine Information that is Needed When You Post a "Car is not Running" or "Car is Running Poorly" Thread
  • AeroCoupe
  • Apr 28, 2025
Fox 5.0 Mustang Tech May 4, 2025
Bullitt347
C
Engine Code 94 and 13
  • CmdrDerp
  • Nov 3, 2024
Fox 5.0 Mustang Tech Nov 4, 2024
AeroCoupe
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
