Octane and Compression Ratio...SCHOOL ME
Black1987Stang
1,422
Jersey Shore
I'm building an all forged 331 stroker with twisted wedge heads, trackheat intake, trickflow stage 2 cam or a comp xfi stroker cam, and all the usual. It has 9.8 to 1 compression with a .040 gasket and the parts that are in it. Will I be able to use pump gas no problem? Like 91 or 93 octane? It will be tuned with a wideband and Tweecer R/t
9.8 to 1 is nothing, 91 or higher will handle that easily. Make sure you have your timing set right and it doesn't run too hot and you'll have no problems with it. I've seen cars with much more compression ratio run fine on pump gas, and even though they have knock sensors and systems that can compensate, many newer cars run more compression ratio than that from the factory.
you should not have any problems pushing 10lb boost with that combo. your cr is getting up there but with a good tune that the tweecer can get you, you should be ok.
i guess that im running about 9.5 to 1 cr and i have plans on going to 8lb and im not expecting any problems with 91 octane and a good ol tweecer tune.
eric
