odometer disconnect?
I think your transmission is the same as mine, and if it is, then yes, you can. Unfortunately you have to disconnect your speedometer too if you do it this way. There's a little plug in the driver's side of the transmission you have to take out to chage your speedo gear when you get change gears. If I'm right, if this is unhooked, nothing should work. Don't forget though, this is ILLEGAL and I hope you're not using this to "save" miles on your car or anything.
