Odometer
  • Thread starter Thread starter Black 93 Fox
  • Start date Start date Jun 24, 2005
Black 93 Fox
1,995
Vancouver,Washington
Jun 24, 2005
  • Jun 24, 2005
Is there any way to turn the odometer back to zero again? I am putting a brand new motor in the car and would like to get the odometer to zero. I have the mileage exempt thing on my title. I know that i can buy a new gauge cluster but rather not if i can get around it.
Thanks, Black 93 Fox
z2o_what
309
princeton, WV
Jun 25, 2005
  • Jun 25, 2005
how many miles is on the odo. now
Black 93 Fox
1,995
Jun 25, 2005
  • Jun 25, 2005
165,000 i think
silverstripes
81
monroe, LA
Jun 26, 2005
  • Jun 26, 2005
To my knowledge there is no way without some really special tools that i doubt can be found very easily. Here at my shop we sent them to Lauderdale speedometer and they repair them ,but they are very cautious and will not adjust readings unless two clusters are sent and then they will match if one is broken. I have heard of people spining the speedometer with a dremel but this i have tried myself and would take forever and cost you several dremel tools.
Black 93 Fox
1,995
Jun 26, 2005
  • Jun 26, 2005
Im thinking about useing a drill on the end of the tranny speedo cable cause the motor and tranny are out till this coming week when the new one goes in. I think if i just make it go forward till it turns back to zero it should work. Probaly gona take a while tho.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Jun 26, 2005
  • Jun 26, 2005
I actually think it is not legal to tamper with your Odometer at all! Your best bet would just be to keep a log book and put down the mileage of your install, as the vehicle itself still has the miles on it.
z2o_what
309
princeton, WV
Jun 26, 2005
  • Jun 26, 2005
that was what i was thinking, but i would use a pnumatic die-grinder(with out wheel of-coarse) that spins alot faster that most drills
Black 93 Fox
1,995
Jun 27, 2005
  • Jun 27, 2005
I have a air tool that spins im thinking about useing that pretty sure it will turn faster then the drill. Im gona try it tommorow.
z2o_what
309
princeton, WV
Jun 27, 2005
  • Jun 27, 2005
be careful not to spin too fast, because you might break your speedometer
bullitstang1313
713
Indianapolis / Columbus, Indiana
Jun 27, 2005
#10
  • Jun 27, 2005
  • #10
I pulled the instrument cluster out of my car and took the odemeter apart and then put it back at zero. I tried using a drill at first but it was taking too long. It was kinda a pain to put it back together thats why I just left my new odometer where its at when I upgraded to a 140mph cluster.
89CopCoupe
Banned
Feb 17, 2004
606
Post Count City
Jun 27, 2005
#11
  • Jun 27, 2005
  • #11
A 165K car with a new engine is still a 165K mile car ... why mess with it ... all sounds silly to me.
Especially the possible "new" owner (a fellow Stanger) that may be conned into thinking the car has 108K or whatever is accumulated.
Boo-hiss
Black 93 Fox
1,995
Jun 27, 2005
#12
  • Jun 27, 2005
  • #12
I know that the car is still gona have that many miles on it. But even thoes miles arent correct cause the last owner put in differnt gears but didnt but in a different tranny gear so it showed you going faster then you were actually going. I just want it back to zero cause of the new engine. Im gona try the air tool but not go too fast with it like stated above.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
  • Mindseye007
  • Aug 16, 2026
Mindseye007
E
Drivetrain Odometer quit working
  • El Dee
  • Feb 6, 2025
Fox 5.0 Mustang Tech Feb 7, 2025
85GTStangGuy
