Oem Carb For A 66, 289
  • Thread starter Thread starter escbsap
  • Start date Start date Dec 15, 2014
E
escbsap
California
Dec 15, 2014
  • Dec 15, 2014
Hey Everyone, want to get some advice on whether to get the stock OEM carb, or upgrade to a new performance one? first off, I don't know what the OEM carb model is, so if any can help me with, it would be much appreciated. Second, as for a performance carb, my 289 is a daily driver, so I don't want something that's too high performance mainly cause I want to keep the cost low, let's say under $250. Any recommendations on an aftermarket performance carb would help as well. Thanks.
horse sence
8,611
233
Wile Coyote's stunt double
Dec 16, 2014
  • Dec 16, 2014
2V or 4V ? They were Autolite at first and then turned into Motorcraft ,still the same carb though .
you can get a 600 Holley 4V vacuum secondary in your price range or a 2V Holley .
N
n8rfastback
135
Jan 1, 2015
  • Jan 1, 2015
The autolite 4100 would be fantastic. Check out pony carbs for one built to handle modern fuels. I cant remember if they are pricey though or not. Otherwise you could always go with a holley or edelbrock off the shelf, either way would work. Prepare to do some tuning either way though to really get it running how it should
Y
Speed density 302 to carb 351W
  • yaboity
  • May 29, 2026
  • Fox Engine Swaparoo
Fox Engine Swaparoo May 29, 2026
AeroCoupe
F
3G Alternator install question
  • fathead429
  • Oct 24, 2026
1974 - 1978 Mustang II Talk & Tech Oct 25, 2026
LILCBRA
F
289 to 302 Engine
  • Fri Guy
  • Feb 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Feb 13, 2025
Fri Guy
F
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
