Trouble starting 66 Mustang
Joeny
New York
Hi everyone,
I have a 66 Mustang 200ci that I can't get started, ill give you a quick rundown. The car sat for a few years and I have been working to get it back up and running. I have a new batter, solenoid, starter, coil, and fuel in the carb. the engine is a TDC and I can't get it to start. It will crank all day but won't start, there is voltage to the plugs and coil but won't start any suggestions would be greatly appreciated.
Recheck your basics. Fuel, static timing, firing order. The video sounds like it wants to just not quite. Did you do a compression check. Try a squirt of starting fluid or brake / carb cleaner while cranking. If it fires or runs on spray the carb is gummed up.
