Off Road H Pipe Question.
  • Thread starter Thread starter Benz510
  • Start date Start date May 17, 2016
First Prev 2 of 2
elarm1
1,428
652
154
N.Va
May 18, 2016
#21
  • May 18, 2016
  • #21
I just not too long ago bought my o/r x pipe and it has the tube. My o/r h pipe I bought 5 years ago also had the tube. I thought they all had them
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
May 18, 2016
#22
  • May 18, 2016
  • #22
just run a short belt and be done with it. If you want to clean up the engine compartment, remove the hoses of the back of the smog pump, put a rubber end cap on the metal themactor line off the heads and vacuum caps on the TAB ad TAD lines and tuck them back behind the passenger shock tower. You will not throw off a CEL but it will have codes for the smog pump, TAD and TAB sensors. I've owned 7 fox bodies and not one with the smog pump, TAD/TAB, thermactor lines. Know that it is 50/50 if you notice more exhaust smell without the cats.
Do not remove the EGR unless you get a tune or it will throw off codes and cause some cold start problems.
First Prev 2 of 2
M
Off-road h pipe
  • MadMatt7
  • Oct 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2026
nickyb
Fox Removing smog only questions
  • 91GTstroked
  • Sep 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
91GTstroked
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
Fox BBK X-pipe replacement Cat?
  • TIGGER
  • Aug 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 26, 2025
AeroCoupe
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
