FRONT LCA REMOVAL
After a harrowing experience with my front LCA's, and upon our good friend JT's recommendation, I'm going to post some info that will hopefully help someone else out down the line. With the age of our cars, it will become increasingly more common to see seized bolts in areas that haven't been touched since the build date of the car. One of these areas is typically the front (and rear) LCAs. This tutorial assumes that you know how to get the brakes, struts, springs, endlink and spindle off of the control arm. If you're having trouble with any of those areas a search should help you. This method assumes you are using NEW LCAs, and not reusing your old ones.
TUTORIAL:
The problem is not so much that the problem bolts won't spin, rather that they won't come out. It's pretty common that the front bolts seize into the control arm sleeve if they haven't been moved in 13 years. For me, the rear most control arm bolts came out with ease, but I have no guarantee that anyone else's situation will be the same time
If you are able to remove the back nut from a problem bolt, ideally the bolt should simply slide out. Reality is somewhat different however, and even with a BFH it will most likely refuse to budge. My only option was to cut the suckers out.
tools used:
21mm socket and appropriate breaker bar
21mm wrench
15/16 wrench (or equivalent in mm - this is for the nuts on the bolts)
reciprocating saw (optional, and not recommended for cutting off the bolts, only recommended for cutting off the control arm)
Angle grinder (bigger is better, but I did it all with a 4.5" unit)
Eye protection
BFH (but not too big)
PB blaster or equivalent
Patience
1. Remove rear front control arm bolt (this one should come out smoothly - at least both of them did for me )
2. Waste 2-5 hours breaking sockets, bruising hands, getting PB blaster in your eye, etc trying to get the front bolt out.
3. Take an angle grinder or reciprocating saw to the arm, cutting it so that only the small part of the arm extending from the problem bolt remains.
4. By this point, you should be able to get the bolt to atleast spin, because you will have better access to hit it with a BFH.
5. Remove the nut on the back of the bolt
6. Spin the bolt (it will move what remains of the control arm with it) so that you have an optimal angle to get the grinder in there.
7. Grind away on the rightmost bushing, spinning the bolt as necessary for clearance. Try not to breathe in the burning bushing...and take it off as soon as you can so you don't breathe in more than necessary.
8. Once you get through the bolt, pry the sleeve towards the gap you have created with the grinder. This should give you sufficient clearance to cut the other side of the control arm bushing.
9. Install new control arm
I will try to get pictures for clearer reference. I can mock up the entire situation still as I am waiting for parts before I rebuild.
