OH MY GOD!!! PLEASE HELP!!!
Earlier today I posted a thread about changing my coolant. I got the information I needed and went ahead with my project. Everything was going well then all of a sudden my drain plug BROKE!!! The head of the bolt broke that is.
Okay, this is what happened. I drain all the old coolant out. Filled it back up with plan tap water from my garden hose. I started the car and let it idle for like ten minutes with the heater on full blast. I go under the car to remove the drain plug so it'll drain out the water. As I was trying to remove the drain plug it just broke. Only the head of bolt. The part that is in the threading is stuck. Why the hell did Ford put a plastic drain plug??? Why??? How dumb is that. Now I'm stuck with just plain water in my radiator with a broken bolt. I called around everywhere to see about my problem but no one seems to know how to resolve my problem. The dealers were closed when I called. So I just called the local part stores. Can the bolt be removed somehow and be replaced.
Please, please, please don't tell me that I need a new radiator. Can someone help me. Did anyone else go through this before? I own a 2000 GT BTW.
I'm searching all over the internet and nothing comes up when I type in Mustang radiator drain plug replacement. All the local stores don't carry them either. They can't even special order it. Tomorrow is Sunday and all Ford dealership parts dept. is closed. I need a new plug ASAP so I can drain all this water out and put in some coolant. It's been so hot latey and I don't want to risk the chance of overheating. It's my only transportation.
mustang2 said:
Can't you drop the lower rad. hose to drain it for now?
I'm an iddiot. Why didn't I think of that. That's the perfect fix for now. Too bad it dark out right now and I don't feel like crawling all underneath the car to do it.
One more question...When I removed the bolt the first time to drain fluid, why did it not come out all the way? It was like you could only unbolt it to a certain point and it doens't want to come out completely. How can the bolt be replace if it's like that?
I don't have a newer Mustang, so I would let somebody else comment on this also before you do it. But there should be a small o-ring inside the plug, after you unscrew it as far as it will go, pull it out with a pair of pliers. The o-ring is what makes it not come completely out when your unscrewing.
