oh no, not enough fuel?
D347643
Banned
Jan 28, 2003
1,095
portland, OR
ok this is my setup
twisted wedge heads
street heat intake
76mm mass air
cold air intake :rolleyes:
stage 1 cam
pulleys
moros electric water pump
24 pounders
my q is.... im still running the stock pump, is that bad news, im startuing to think it is? i plan to get a turbo in a few months so i might as well upgrade if i need it.
thanks,
Drew
I agree with the fuel pump...adjustable fuel pressure is not neccessary sine the stock one will do fine...what good is the fp if you are going to run it at the stock psi? however, your C&L can contribute to your car running lean...what you can do is try to rotate the MAF clockwise or counter-clockwise...to find the sweet spot...
