Oil blow by
nicklats
63
I have an 88 turbo coupe motor in a 93 mustang with a 93 valve cover. I have a little air filter/breather and im having alot of blow-by what type of system do you guys recommend for containing all the blow-by oil.
I had some blow-by on my 86 turbo coupe motor in a 89 mustang. I put in new valve seals, a Ford PCV valve change to 88 turbo coupe valve cover and a Ford valve cover gasket expensive but doesn't leak. Run filter off valve cover to intake of turbo. Also run compression test to see if you have too much blow-by from the rings or maybe headgasket hope this helps
