  • SN95 4.6L Mustang Tech
Oil filter magnets
  • Thread starter Thread starter Dark Knight GT
  • Start date Start date May 3, 2004
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
May 3, 2004
  • May 3, 2004
I've seen some of these "oil filter magnets" around. They are a flat magnet piece that you place on your oil filter. It is suppost to help trap metal particles and fragments in your oil filter and keep them there by the "magnetic pull". When you change your oil filter, the metal particles go with it. Anyone ever try these ? They look pretty nice, I might try one.
USMC03GT
144
Jacksonville, NC
May 3, 2004
  • May 3, 2004
Wouldn't waste my money on it. Any quality filter that you put on your car will take care of anything that will cause damage. Just think about how many cars don't have these and have plenty of miles on them. If you're engine is putting that much iron into the oil for the magnets to make any difference, then your engine is shot anyway.
My .02
GOLDENPONY
1,503
LOVELAND, OHIO
May 3, 2004
  • May 3, 2004
Filter Mags
I haven't used them but I have read a couple of articles that say they work well
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
May 3, 2004
  • May 3, 2004
I have read a few too. This really makes me curious.
85GTlover
704
  • May 3, 2004
For an older motor with more wear I think it would be more effective. If it is not expensive why not try it though? Like the other guy said that is what the filters anyway, but at least you know the magnetic particles are on the magnet rather than circulating through the engine if you do use one.
85GTlover
704
  • May 3, 2004
don't wanna read it again I bet.
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
May 3, 2004
  • May 3, 2004
I think I'll try one and I'll let you guys know how my oil changes go. I use Mobil 1 oil w/ Mobil synthetic oil filter. I guess the magnet will be the cherry on top. Thanks for the replies.
mustang35thann
354
Rochester, NY
May 4, 2004
  • May 4, 2004
Where did you see the oil filter magnet? I was also looking for a magnetic drain plug. Any suggestions? Also, what size is the drain plug on a 99 GT? Is it metric (15mm) or standard (1/2")?
8yourZ06
128
  • May 4, 2004
Your oil filter already traps what a magnet would attract to itself. Most oil filters only trap between the 20 to 40 micron range but a magnet won't be of much extra help.
ZIPP0
781
Philadelphia
May 4, 2004
#10
  • May 4, 2004
  • #10
I hear those things work
mustang35thann
354
Rochester, NY
May 4, 2004
#11
  • May 4, 2004
  • #11
The engine builders I've talked to recommend an oil filter magnet and magnetic drain plug. It's a little extra protection for not a lot of money.
E
E-MACH
#12
  • May 4, 2004
  • #12
Forget a magnet for the oil plug or filter...what we need is something to collect all the fragged-off metal in the Tremec transmission. I can only imagine what that soup looks like. With all the daily grinding of synchros and gears it must be like one of those Christmas snow globes all shook up. My 2¢.
chevylover
190
Castro Valley, CA originally St. James Missouri
May 4, 2004
#13
  • May 4, 2004
  • #13
http://www.lube4life.com/magnets.htm
http://www.filtermag.com/
Here's just a couple of places I've visited frequently.
Filtermag seems to be a very good product, I've never used one but it looks good and sturdy.
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
May 4, 2004
#14
  • May 4, 2004
  • #14
The oil filter magnet I seen was pretty big. Looked large enough to wrap around your entire oil filter. It was wide too. It was 42 bucks at a local performance shop. Bit expensive but for its size and since its a one time investment, might be worth it. They are strong too. Had to use both my hands to sepereate the magnets from each other on the shelf. Couldnt just do it with my fingertips.
I'm thinking, I wonder if you could add a bunch of these to your oil and transmission pans. Then, when you drop the pan out, you can clean all the metal particles trapped on it ?
StngStr
616
Central Florida
May 4, 2004
#15
  • May 4, 2004
  • #15
In my 99 Dakota R/T, there was a round magnet attached to the bottom (inside) of the transmission pan. When the tranny gave out, that magnet was about 3 times the original size just from all the metal **** stuck to it.
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
May 4, 2004
#16
  • May 4, 2004
  • #16
Most transmissions have this. They put a little metal magnet in there to trap all the metal. You clean it whenever you drop the pan.
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
CFI to carb conversion question
  • StockerStang
  • Mar 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 11, 2025
AeroCoupe
