Since getting new Cobra I/T for my 86gt, i've had some idle issues and doesn't seem to make as much power as predicted. Have noticed a lot of oil in upper I/T, and #4 & #8 plugs were oily, cleaned it out and rerouted pcv vac line. next day, still oil in upper. This new cobra has different locations of vac fittings as stock 86 upper or 88 upper that i had been using. With 88 upper all vac lines went to fittings under intake, there were 3 plus the tree, i had brake boost,fuel pres, and small blake line to tree. Pcv, map & a line from air pump canister to 3 fittings under intake. With cobra , it has one fitting under intake, plus tree, and one on driver side of intake. And one on neck of intake near T/B, I've tried a couple of different combos, for the routing of the lined , but still oil in intake. Can any one with 86 gt , or 87 to 88, tell me the proper routing , or my oil is getting in intake. I wasn't having this problem with old set up. Can the oil effect the sensors? thanks for any advice
since metered air is not an issue).
