txstang84
GREG91GT said:I have the same problem with my systemax intake, so i put a clear fuel filter in the vacum hose between the pcv and the intake and i also run a push in breather in my valve cover.
txstang84 said:you guys are just too nice-so i should watch out for oil in my intake since i'll be running a cobra when my 331 goes in...1EVIL88VERT also has had problems with that one, when we pulled the upper intake the back four runners were all wet with fresh oil, the hose from the pcv to the plenum was full, and the plenum itself had a more than fair amount of oil in it...we've tried more than one remedy with this one...
i'm seriously thinking about rerouting the hose from the pcv valve to a different location on the intake hoping that maybe that will slow the pull of oil coming from the lifter valley....hopefully
txstang84 said:we did do a lk-down and compression ck with excellent results-the worst cylinder was only 10psi less than the highest-the highest being 160psi...that and the huge puddles of fresh viscous oil in the pcv valve, pcv hose, and intake plenum are why i personally don't think it's a blowby problem...in addition, it's a fresh rebuild with standard tension rings (i noticed you made reference to that earlier), good bores, and everything was professionally cleaned and clearanced.
it's got us both kinda confused, but like i said there have been some changes to try and slow it down, which have worked with marginal success...it still burns a little bit, but only when it's hot started-now we both think that might have something to do with valve stem seals...
Agreed! It would be like having a leaking roof and putting a bucket under the drip. Sure the floor stays dry, but to fix it one has to fix the roof. The oil in the intake, TB, etc is just a symptom in the middle of the closed-loop path. Get it at the source and it should go away.vristang said:My response to both of you guys is the same. The intake most likely has nothing to do with the oil control problems you are experiencing. From my personal experience and what I have seen on this site, it is usually related to blowby. If putting a fuel filter on the PCV line keeps some of the oil out of the intake, that's great! But it doesn't fix the problem. The PCV and oil filler line should have no problem venting crank case pressure in a normal way (You may have issues if you are running boost however).
vristang said:Yes, low tension rings suck @$$.
After reading this I am dumbfounded. With good compression readings within 93% if I know my math (and I usually don't), you should be fine. What were your leak down numbers like? Sometimes this can give an indicator that the compression check misses due to bore wear not being consistent along the length of the bore.
Valve seals are definitely worth looking into. However I am having a hard time seeing how this will cause oil to blow out of the crankcase, or be sucked into the intake, depending on how you look at it.
I can't think of a reason why oil would only be burned on hot start either.
Can you list the changes you have tried and what the current setup is? It may help.
txstang84 said:i can't remember exact numbers from the lk down test, but I do remember there was no reason to believe that blowby was a problem. See, this is where I'll stand by my original belief that the cobra intake just sucks the oil right out of the lifter valley (which makes absolutely no sense whatsoever). Before that swap was made, this freshly rebuilt engine (which normally will burn a small amount of oil until the rings seat) burned virtually nothing at all, never a minutes trouble...then we installed the cobra intake and lo and behold, there's oil being pulled from the crankcase with no loss of power...aside from the fouled plugs. On a trip to the dyno (about two+ hours away, it burned over a qt of oil) So, we discovered that we'd routed the line in the wrong way...ok, fixed that to the way it's supposed to look...mostly worked
Well, it finally stopped burning oil...or so we thought, then the damn thing starts burning it again-but this time only on hot starts...like an old worn out chevy 305 with bad valve stem seals (once again, makes no sense-BRAND NEW heads, not reconditioned)....ya know, that small cloud that billows from the pipes until the engine feels like stopping. When it's running and warmed up, you could beat the dog out of it, nary a puff of oil smoke-but when you shut it down, and come back in a couple minutes, there she is...poooof, and then it clears up after a few moments....and the plugs don't show any fouling...yet another reason for me to believe that it's not blowby, but stem seals instead...maybe all the oil being pulled from the intake messed up the stem seals-IDK...
vristang said:Do you still get oil in the intake? I think if it were just bad valve seals there would not be puddles up near the throttle plate or along the upper manifold at all. How much is the oil level dropping? Is it back to where it should be? The reason I ask is that if the plugs are not fouled and the oil level is not dropping then it could be that you are burning something else, like coolant. Is the cloud of smoke there at cold start. Here's my thought, if you have a small leak in the head gasket there would be very little smoke coming out of the exhaust when it is warm and running steady. When the motor stops there is less pressure in the cylinder than there is in the cooling system, so water trickles into the chambers and pools up. You start the car and out comes a big cloud of smoke. This is only a theory though as I cannot tell what the smoke looks like from here. Oil smoke should be blue, coolant smoke should be white? You could also have someone stick their hand under the exhaust pipe when you warm start the motor. If they feel moisture on their hand then there is a coolant issue. This is the best I can come up with, even if it is a long shot. However, you would not be the first person to fix one problem just to have something else get screwed up.
Could be other sources of fluid leaks as well, such as oil past the valve seals, coolant past the lower intake manifold, coolant from the EGR (if you have it hooked up). I am just thinking out loud right now hoping that something will ring a bell for you.
I'll keep trying to help as long as you keep coming back.
sweet88gt said:I am intrested in the pics for the added baffle. As far as the info I provided it seems in my case to be the culprit of blow by in a otherwise worn motor. I guess I should have said that. I try to only post when I have dealt with the same problems most of which have been recently. But I am still learning and the curve is large. I believe the original post didnt say much about a rebuilt engine and was focused on his post.Sorry for the confusion.
