oil in my superchargers intake
stanggt00
371
baltimore md
i upgraded the 3.5in intake that came with my mongoose kit to mph's 4in intake pipping
doing the install i noticed oil in the intake near were the supercharger blades are and in the tube leading the the supercharger
is this normal or is it a problem
and if it is how do i stop the oil from getting in there
interesting....I've never even thought to look for that...
On a side note....have you put the powerpipe on and done some driving...I'd like to know if it adds a noticeable power increase for SOTP driving....mine is on order now:D
When I do my install I'll let you know if I notice any oil residue
An oil separator will not solve his problem. Do you have the stock cam covers? If so, then I'd suspect that Built98GT might be right. To verify, you could disconnect the hose from the drivers' side cam cover to the Power Pipe and see if it has oil in it (blow some air through it). Oil should not be coming out of the drivers' side cam cover, as that is the INLET for the PCV system.
No to sure about the V8's
I know on smaller older cars i.e 4 pots when turbo'd or SC's they have a tendancy to cause the oil sump to presurise slightly and it forces a bit of oil up to the air intake breather pipes. I heard this was normally caused by blow by or worn piston rings. Were a small amout of air is leaking passed the piston rings.
i just got the kit from mph less then 3 weeks ago
i installed the kit i dont like shops touching my car then just dont seem to know what the hell they are talking about
i use to have the same kind of problem with my ford probe gt remove the intake and had some oil in there did not hurt anything but i still would like to know why its happening
there is no oil that i can see in the tubes comming from the valve cover it almost looks like the charger is spitting out the oil
its not a lot of oil but is noticable when you look in the intake
no idea if the power pipe help i have not seen a dyno yet so i have not really gotten on the car hard
