  • SN95 4.6L Mustang Tech
Oil Leak....
  • Thread starter Thread starter 97GTSTANG
  • Start date Start date Oct 14, 2005
97GTSTANG
852
Virginia
Oct 14, 2005
  • Oct 14, 2005
Well guys, seems like the car is losing some oil and it looks like its around the oil pan lower timing chain cover area. its covered in oil and i was wondering what you all think it might be. I started noticing it 3 months ago after the tech changed my oil and he said to keep an eye on it. Well i went to get an oil change today and the car was short about half a quart of oil. He was saying to pour some dye in the crankcase and it will bleed through where ever the leak is coming from exactly. They wanted to charge $140 for that service. Do you all know where I can get the dye to pour in the crankcase and see what the problem is and have you all had any problems with losing oil in the areas described.
Thanks guys
5.0's 4 ever
The #1 Stunna
5,794
Orlando, FL
Oct 15, 2005
  • Oct 15, 2005
Autoparts store should carry engine oil dye. It will probably cost around $10 or more for a tiny little bottle. You will need a black light to pick up the dye though once you have poured it into your engine. From what you describe it could be leaking from the crank seal or possibly pan gasket.
97GTSTANG
852
Virginia
Oct 15, 2005
  • Oct 15, 2005
yea possible from the crank seal, the tech said it looks mostly from the oil pan. So maybe the gasket is bad. Its just that when i drive the oil goes everywhere so its hard to see where its coming from.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine Gas in my oil
  • limp
  • Jun 15, 2025
2K
Fox 5.0 Mustang Tech May 16, 2026
Mindseye007
Engine New Oil Leak Help.
  • Slo5Oh89
  • Mar 14, 2025
Fox 5.0 Mustang Tech Mar 19, 2025
Slo5Oh89
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
keel
