Hey, I've got oil dripping from the pan at the bottom drain bolt, it doesn't fully tighten and keeps spinning so I know either the pan or bolt is stripped. I've also got oil dripping down from the front of the transmission right by the oil pan. Is this the rear main seal? I ran the car for 5 minutes this morning and checked the oil level, it was about a quart low, but 5 minutes may not have brought it to operating temp (I'm unsure as almost all of my gauges don't work). How does engine temp effect dipstick readings, would hotter oil read higher or lower? Is it possible to just get a bigger bolt for the pan? Thanks in advance
