oil on top of timing chain cover
rockyracoon
874
27
49
margate NJ
I just noticed a little oil welling up on top of the t/c cover.I replaced the chain a few weeks ago so im thinking that maybe I didnt seal it up properly
its not leaking bad enough to drip down, it is just sitting in that little valley.
I guess ill try and tighten up the top bolts and see what happens.
ya know what thats what I thought at first cause it is welling just below the dizzy and like an inch to the right,but it looks dry right at the dizzy,plus I didnt pull it
when I did the chain.I dunno allways something.well anyways if I end up pulling the cover thatll just give me an excuse to upgrade the cam,I was planning to wait till next winter though.
Check lower intake where the silicone/gasket seats against the block and the O-ring (as mentioned)...
Did you use a timing cover gasket or just rtv or both?
