  • 1994 - 1995 Specific Tech
Oil Prime????
  • Thread starter Thread starter Yobi1Kanobi
  • Start date Start date Jan 7, 2008
Yobi1Kanobi
559
  • Jan 7, 2008
Whats the proper way to Prime the oil in the Motor.
HISSIN50
34
129
Jan 7, 2008
  • Jan 7, 2008
Oil doesnt require priming.
You can pull the dizzy and use a priming tool attached to your drill. Or use extensions and a socket (not as smooth a way of doing it). The tools are cheap.
The drill needs to be reversible and have a little bit of oomph to it.
Good luck.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jan 7, 2008
  • Jan 7, 2008
Try one of these...
Link
If you do not get a drill with some power, you could burn it up. It needs to have some torque to it.
You install the primer down the distributor hole on the oil pump driveshaft, then put the drill on the primer tool.
Make sure the drill is going in reverse (counterclockwise), and start cranking
Should take 30-60 seconds to build up some oil pressure.
You can watch it on the guage, and you will feel it when you get some oil pressure.
Many times, a good indicator of proper oil flow is to watch the oil come out of the top of the pushrods.
NKau
1,346
Jefferson, WI
Jan 8, 2008
  • Jan 8, 2008
I actually dismembered an old TFI distributor I had laying around and used that as my priming tool and spun it with a drill like previously mentioned. Just an idea.
Yobi1Kanobi
559
  • Jan 8, 2008
thank gonna pick up a tool. thats the exact anwser i was looking for...
Badazgt.
115
  • Jan 9, 2008
i read one time that like 80% of engine wear comes from starting the motor before oil pressure builds...
dont know if it helps or not but i always put my foot in the gas and turn the motor over a few times to get some oil goin... anyone else do this before they start?
OrangeMustangGt
1,976
Cape Cod, MA
Jan 9, 2008
  • Jan 9, 2008
you dont need a tool. Just use a deep 1/4" 1/4" drive socket with a long 1/4" extension electrical taped on so you dont drop it. then check it into a 1/2" chuck drill....done
  • Mindseye007
  • Aug 16, 2026
Mindseye007
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Need help ordering a oil cooler and filter relocation kit but don't know what I need
  • Aiden Brown
  • Aug 22, 2026
SN95 4.6L Mustang Tech Sep 14, 2026
squeak93
D
Fox 88 foxbody no power to red and black wire at fuel pump relay
  • drod88
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 2, 2025
Mcmahst
Mustang 2 74’ Oil Pan Help
  • scaryfresh
  • Aug 12, 2026
1974 - 1978 Mustang II Talk & Tech Aug 12, 2026
LILCBRA
