  • 1994 - 1995 Specific Tech
Oil Problems... its everywhere....
  • Thread starter Thread starter mytight95
  • Start date Start date Aug 6, 2005
mytight95
2,605
Dothan,Al
Aug 6, 2005
  • Aug 6, 2005
I have an edelbrock performer intake manifold, i have been gettting a backfire at high rpm on a shift, and oil all over the trans, bell area etc. I decided to pull the intake today to replace the lower intake gaskets as it is leaking on the lifter valley on the back side.... i discovered what is in the pictures....
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Aug 6, 2005
  • Aug 6, 2005
Yup it can kill power by soaking you plugs with oil. Pull them and clean them up a bit, I remember a while ago reading people having oil consumtion problems with e-brock intake. It's been a while since it's come up you may want to try a search. Good luck.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Aug 6, 2005
  • Aug 6, 2005
ps resize pics......
mytight95
2,605
Dothan,Al
Aug 6, 2005
  • Aug 6, 2005
i can't...... my paint doesn't work for some reason on my computer right now...
jason
BLT2BTU
24
upstate NY
Aug 7, 2005
  • Aug 7, 2005
i have the same blow by issues
what is it with these cars????
94TURBO5 O
2,509
VA
Aug 7, 2005
  • Aug 7, 2005
I had the same issues with boost. It started blowing out of my breather and onto my headers. I just ordered an Ecav canister from Shogun and it will be here on Wednesday. I'll put up some pics and a review when I'm done.
I ran a hose from my vent tube in the oil filler neck into a can and WOW lots of friggn oil (~1/4 oz) after a few hard runs. I don't have a hole to run my vent tube into the PTK discharge tube so I had the vent tube capped off, thus making it come out of my breather. So running it into the vac can will catch the oil. The tube usually runs into the intake discharge tube and gets sucked up the intake.
Do you have that tube running into your discharge pipe going to the tb?
OrangeMustangGt
1,976
Cape Cod, MA
Aug 7, 2005
  • Aug 7, 2005
can you make the pics a bit larger please? they look like thumbnail pics from here.
Anyhow, your car shouldent be throwing that much oil, and if your na, you shouldent need any type of catch can, etc.
Varify your pcv system and all your gaskets are good.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Aug 7, 2005
  • Aug 7, 2005
jason
Get irfanview. It's a great program, and it easily allows for resizing, etc.
Scott
mytight95
2,605
Dothan,Al
Aug 7, 2005
  • Aug 7, 2005
i will work on the pics sizes...... my god/////lol
What gaskets could be bad to cause this...... I have a pcv valve its just one from the parts store could it be letting the motor pull too much vacuum or what....
I wouldn't think it is blow by the motor still has good compression etc....has hair under 100k on it....
jason
mytight95
2,605
Dothan,Al
Aug 7, 2005
#10
  • Aug 7, 2005
  • #10
you gotta love these kind of compliments in a help question or thread... Guess sometimes people just can't help being a smarta$$...
JR, Do you really think that the tube that goes from the valve cover to the CAI could really be pulling that much oil, my valve covers still have baffles. I think it is the PCV system as both vacuum lines that run to it, hook up in the spots where the oil is puddled in the intake. I don't know though i guess it could be draining down there.
O
odiedog
210
Little Rock, Ar.
Aug 7, 2005
#11
  • Aug 7, 2005
  • #11
Oil problems do suck (pardon the pun)
If your pcv is one of those that have a tree of connections, and one of the openings isnt capped or connected then it might cause something like your problem. Or if the pcv isnt the right one or malfunctioning (partially or fully clogged) then the engine would pull vaccuum from the breather tube and suck oil into the throttle body under high load. I went to just a straight breather cap with no vaccuum line to the air intake.
Just throwing ideas out there... Let us know what you find out...
good luck.
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
351W/5.8 EFI intake manifolds fading away...
  • Ryno5150
  • Jan 13, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 7, 2026
nickyb
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
I
Engine Insane fuel trims +25% LTFT Bank 1, -16% LTFT Bank 2
  • imw_stl
  • Aug 31, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 19, 2025
Mustang5L5
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
