It's been a while since I posted anything to exercise your minds, and I have a query.
I've heard high-volume oil pumps are a strain on the distributor gear, leading to increased wear, etc, but would it be possible to run a HV pump with an external line plumbed from the return line of a relocated oil filter directly to the mains oil gallery?
I don't mean send ALL the oil there, have a "T" piece, sending oil back to the filter relocation block, and to the mains gallery, so the mains would get two feeds.
I believe you're supposed to feed the mains with an external pump, so I'm wondering if this idea would work, or would it just destroy the oil pressure?
I'm thinking increased pressure from the HV pump, but countered by the increased flow to the mains, which would bring the pressure back to where it was previously, but flow more around the main bearings.
Has anybody done this, or know anything that will help? Anywhere I can read about it?
Thanks in advance
Thanks in advance
