Well after a couple of days of tinkering here is the finished product. Since my upper/lower intake install I have had issues with oil basically flooding the upper from my pcv, and it covering the back 2 plugs with oil. Im talking about having to add half a quart or so every 500 mile bad. After talking with a few guys on here via pm, I decided to yank the upper and replumb the pcv lines. I installed a new pcv valve, new screen, new line from the upper all the way through, installed a Amflo Inline air filter (to act like a catch can), and an Advance Auto see through fuel filter. I mounted it all around the ac line that runs behind the upper.
Basically now the air/oil mix goes through the pcv, into the air filter/catch can, into the fuel filter to separate out any leftover oil/air/condensation mix, and finally into the upper intake.
I did a pretty ok job on it I think. I would have liked to find a way to mount the stuff without using zip ties, but I didnt feel like drilling any holes around the fire wall ect...
Looks pretty "factory" looking to me, and if you dont know what your looking for then most people would probably overlook it.
I drove her about 30 mins this am, and had zero smoke on acceleration. Ill know if its really working as the week progresses.
Thanks to those of you guys I pmed about this pcv issue, your insight helped me piece this badboy together.
Except if there be a pressure differential between the intake and the crankcase it could make the whole thing worthless/worse.
