I installed a Steeda oil separator this week....after a week of rain I was finally able to drive it some...
I put like 10 miles or less on it and was anxious to check out the separator and see if it worked....WOW....I had about 1/4" of oil in the separator...
Just about what the pic shows...
I knew I was losing oil as my intake spacer was saturated and knew something was up and she was drinking its fair share....I had a new valve and lines too...I has this problem when it was pretty much stock...adding H/C/I seemed to add to the problem..
anyway, just wanted to share....amazing how much oil it could drink inbetween oil changes...i mounted mine just like the pic....was very easy to do..from the PCV valve to the IN side if the separator, then run the OUT line back to where your PCV line feeds into the upper...tit...
For a worthwhile mod that works...I give this one a 10...
Theyre at Walmart in the car section for $12. But of course you dont get the bracket with it. (just messin with you)
